Old 05-05-2004, 02:27 AM
Shawn C Shawn C is offline
Default I forgot to mention...
what I had to do to the E-Brake lever. At some point I pulled to hard on the lever trying to get the original e-brake to work and I managed to bend the lever prety good (or bad, depending on how you look at it). The lever design is actually not very strong. I TIG welded a couple of gusset plates on the sides where the cut tubing meets the 1/8" flat plate pieces at the bottom. If you have had the lever out and looked at it you know where I'm talking about. Has anyone else had this problem? I didn't pull on it that hard, heck I aint got enough fingers left on that hand to pull hard!
Ciao,
Shawn C
