Old 05-07-2004, 09:29 AM
smash smash is offline
Question Strange things are afoot at 289 valve adjustment time!
OK, so I have a 289. Somewhere down the ownership line it was claimed to be a hipo but it has stock 289 heads so....working on the basis that it was likely stock bottom end, I adjusted the valves on one cylinder bank as hydraulic and therefore just nipped up the lash.
What a transformation - the car would hardly start let alone run!! The gases coming out of the 'zero lash' side exhaust remained cold suggesting it wasn't firing at all - oops.....
I adjusted the valves back to 'hipo' clearences and it was back to business as usual.
Is there any easy way of determining whether I have hydraulic or solid lifters? If it's a non standard cam, how the hell do i judge the clearances?!!
Interestingly the engine does have a thicker than normal harmonic damper and was also fitted with an autolite dual point dizzy - both of which are easy aftermarket add ons so don't necesarily prove much.
I'm confused!
