Thread: What Happened?
Old 05-12-2004, 01:12 PM
Joe Prochazka Joe Prochazka is offline
Cobra Make, Engine: Unique 427SC-Junkyard 390 with a few aluminum parts-toploader
Coonman..
shifter goes into reverse equally well whether cold or warm.
I do have a Lakewood and I did use a dial indicator to check alignment and it was almost dead nuts on. If I remember it was about .002 out in one quadrant.
just checked fluid level in TOB and it was a little low. No obvious leakage however I did reached inside the Lakewood and felt a light film of fluid at banjo fittings. They are probably starting to leak. I did bleed TOB and top off clutch master cylinder before I took the car out.
