Old 05-12-2004, 06:28 PM
Hal Copple Hal Copple is offline
Cobra Make, Engine: Superformance, 396 CI
good advice, a big difference with small tp changes, 18 psi is what i also run on the street, and the avos' i used to run i put a six clicks from soft, be sure you are turning them the right way, you would be suprised at how many AVO cars come in with the clicks vastly different on the cars. Check the arrows on the click adustment!. Also, sometimes on the AVO's the urethane bushings pound out, but can be re-ordered and pressed in, check to see if you are riding steel on steel, instead of an intack shock urethane bushing. I had two go out.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
