Installing a dash-mounted rear-view mirror
Just got my Finish Line rear-view mirror. It came with two wood screws (image attached). The screws look to be about 1/8" diameter (inside the ... uh ... blades? Not sure what to call the part that actually makes it a screw). Should I drill a pilot hole, and if so, is 1/8" the appropriate diameter?
I've got a great (if under-maintained by me) finish supplied by CR in '92, and I don't want to hurt it - will I run that risk either drilling the holes or inserting the screws?
Thanks,
JLW
