You will need a pilot hole or risk chipping the surface layer. Not sure if 1/8" hole is correct. If you have a hidden area, you could experiment or call Finish Line for advice.
I was able to get to the underside of my dash, so I drilled clearance holes and bonded a small 1/4" plate to the underside that is tapped. Then substituted stainless machine screws for the wood screws.
