Old 05-15-2004, 12:49 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Joe, I'm not sure the mechanical secondary carbs will fit your manifold...have you tried fitting the 450s on the manifold? Maybe Blue Thunder makes their manifold with a little more space so the secondary metering block will fit, but on my Fomoco manifold you HAVE to use vacuum secondary carbs, and you HAVE to turn them around backwards to clear the distributor...
Ken
