Old 05-15-2004, 05:37 PM
tcolley1's Avatar
tcolley1 tcolley1 is offline
Cobra Make, Engine: Unique 289 FIA with Southern Automotive 351 Windsor
Arrow Street Legal FFR Spec Racer PRICE REDUCED
Well I have finally gone and done it! I reinjured my back last week bad enough for my doctor to say "GET OUT OF RACING FOR GOOD"! And if you don't your next visit to me will be for a total fussion. NUTS!
So I am reluctantly putting Falcon65 up For Sale.
I would entertain taking a 1965/66 Mustang GT350R Clone and cash in trade for my car.
If you are seriously interested please email me or give me a call.
Thanks Sergio for putting this together for me so that I could properly tell my storyl
Regards,
Terry
Engine
93 Mustang 302 engine complete rebuild including:
  • .040 overbore (309 c.i.)
  • New pistons and rings, resized rods with ARP bolts
  • New insert & main bearings (0.10 under)
  • New cam bearings (std)
  • Polished Crank
  • Triple Angle valve job
  • New valve springs and guides
  • New Camshaft
  • New lifters
  • New Water Pump
  • New steel distribuitor drive gear
  • New Control module
  • New Distribuitor cap and rotor
  • New 9MM Ford MotorSport ignition wires
  • NewFord MotorSport 50oz. steel flywheel
  • King Cobra Clutch, pressure plate and throw out bearing, extended clutch arm
  • Under drive pulleys
  • Mac unequal lenght headers
  • New alternator and starter
  • Lakewood bell housing and engine plate with custom made aluminum spacer
  • New oil lite bronze pilot bushing
  • New remote oill filter and oil cooler with AN-8 lines
  • New Levy Racing oil pan with windage tray
  • FFR J-pipes with O2 sensors mounted to FFR sidepipes painted with VHT hi-temp paint
  • Valvoline 10w-30 Dura-Blend oil
  • Engine completely balanced
Transmission
3 Mustang T-5Z built from new parts by Glen Buzek, including
  • New Main shaft cluster, gears, syncros, sliders, steel bearing reatiners
  • New .068 5th gear
  • New triple adjustable clutch quadrant
  • New Clutch cable
  • New custom Mid-shift kit with
  • New Pro 5.0 shifter and shifter handle
  • Custom bent clutch and brake pedals
  • Modified Gas pedal
  • Redline gear lube
Driveshaft
Custom made and balanced 10 ˝" long with New front and rear U-joints
Rear Axle and Suspension
93 Mustang housing with:
  • New Ford Motorsport 28 splined 5-lug axles
  • New axle bearings
  • New 3.27 ring gear and pinion
  • Rebuilt Traction lock
  • New Ford T0Bird 10 ˝" vented rotors
  • Rebuilt '87 Seville single piston Calipers
  • New Aeroquip stainless steel brake lines
  • New 3-link suspension with Pro shock coilover springs (400lb)
  • Stainless steel limiting straps
  • Rebuilt Fiero emergency brake handle mounted to left of driver's seat
Fuel System
  • New fuel safe 20 gal. fuel cell with
  • New high-volume in tank fuel pump (2)
  • New tank vent
  • New Fuel safe roll over valve
  • Custom made fuel inlet from body to tank (much safer than donor)
  • New remote fuel filter
  • 3/8 " steel fuel lines from cell to engine with
  • New hi-pressure fuel injection hoses
Electrical
  • Complete Custom modified 93 Mustang wiring harness by EE (Bobby Hughes) with fuse panel under dash on passenger side
  • Ford Inertia switch in trunk
  • New Autometer gauges (tach, oil temp, oil pressure, water temp, fuel level, volt)
  • New master kill-switch mounted on dash (kills battery & alternator)
  • New fan, horn, turn signal, lights (hi-lo beam), hazard signal and ignition switches, air-horn
  • All wiring wrapped in new plastic bundling
  • Headlights, tail lights and license plate lights have quick disconnect plugs
  • New battery recess mounted in the trunk for better weight balance
  • New relays and fuses
Safety
  • New Ultrashield Aluminum high-back racing seats with gray cloth covers
  • Simpson 5-point harness on passengers side
  • Ultrashield 5-point cam lock racing harness for driver
  • Brake proportioning valve mounted next to driver on tunnel
  • Fire system handle mounted on tunnel next to driver
  • Custom steel seat brackets bolted to steel plates welded to the frame for both passenger and driver
  • In most cases ˝” and 7/16” GRADE 8 bolts and Allen bolts used through out the entire chassis, rear end, seat belts, seat frames and seats, front and rear suspension pieces, etc.
  • Lakewood Steel Bell Housing and motor plate
  • 3/8” steel drive shaft loop (360)
  • 1/8” steel “anti-intrusion” plates welded to both the driver and passengers side NASCAR styled door beams
  • .040 aluminum panels with heat insulation in cockpit to protect driver and passenger from exhaust and engine heat
  • Dropped foot box on drivers side and dropped and extended foot box on passengers side
  • Entire floor foot boxes and center tunnel insulated inside and out for safety and comfort
  • NEW remote 5 lb fire system actuated from cockpit with nozzles in cockpit and under the hood
Radiator
  • New custom brass 3-core radiator withMoroso T-filler, 1-qt. overflow bottle, 18 lb pressure cap on radiator, 16 lb cap on T-filler
  • New upper and lower Gates radiator hoses and clamps
  • custom made steel radiator support (does not just sit on light weight aluminum)
  • New 98 Mustang 2 speed fan
  • All ducting sealed so air must flow through radiator
Front Suspension
  • New Factory Five upper and lower tubular control arms
  • Bump steer kit
  • Ackerman steering modification
  • New Flaming River 15:1 quick ratio rack and pinion steering
  • New Mustang SVO 10 ˝” 5-lug vented rotors
  • New wheel bearings, races & seals
  • Rebuilt 93 Mustang single piston calipers
  • New metallic pads
  • New Aeroquip stainless steel lines
  • Rebuilt '87 Fiero/Blazer dual master cylinder
  • All lines shielded from exhaust heat with insulation
  • New coil over springs (600 lb) with Pro Shocks
Body
  • Factory Five body completely seam filled with the best materials
  • Front “quick jack” holes filled in
  • Body split in half at middle of the door on both sides for ease of removing to work on chassis
  • Body is bolted down in the front with the four 5/16” Allen head bolts and four 5/16” Allen head bolts on each section (front ˝ & back ˝ of body) and four ˝” bolts in the rear
  • All drivers side foot box sections, rear bulk head, trunk sections and inner fender panels are sheet metal screwed on for ease of maintenance
  • New quick release windshield kit is installed
  • New removable racing windscreen
  • New removable quick release leather racing steering wheels
  • Doors cut out for more arm room and are installed with hangers and dzus fasteners
  • Body is painted WHITE with a single BLUE stripe in PPG base coat clear coat
  • RED FIA stripes are 6” wide each and are industrial vinyl but can be easily removed
  • Hood is pinned with lockable handles and is the trunk lid
  • Mirrors are installed with cert nuts and screws
  • Custom made 5,200 RPM hi-intensity led shift light is mounted on the dash
Tires and Wheels
  • New 17” x 9” Cobra R replica wheels fitted with
  • New “heat cycled” Kumho Victorracer V-700 275/40 X 17 VR tires
Contact and Price info
Terry Colley
(713) 729-8736
falcon65@houston.rr.com
Enter build website for more pictures:
www.falcon65.com
Enter Presentation website:
www.coolcobra.com (made by Sergio)
Price: REDUCED TO US $29, 500.00 OBO
CLICK HERE TO PRINT A FLYER !
PICTURES:
(click to enlarge)
http://www.33autos.com
Authorized Dealer/Assembler for Unique Motorcars and Southern Automotive Engines.
