Old 05-18-2004, 08:29 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Paul, Pete can help with the clutch pedal. The only way to setup the trans is with a hydraulic throw out bearing. You can use a stock bellhousing but I would suggest a scattershield. You will need to mount a clutch master cylinder on the firewall and fabricate a mounting point on the clutch pedal for the rod. I would suggest you call David Kee or Southern Automotive as I'm sure they can set you up with everything for the changeover.
Don
