Thread: Front tire size
Old 05-20-2004, 03:05 PM
badrich badrich is offline
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Jerry: I presume you are running negative camber, but if not you might consider up to a couple of degrees negative camber. Tire mileage might suffer a tad, but the increased cornering ability will be worth it. And the top of the tires will tuck in a little bit. Good luck. Rich
