Well, you 've already determined that the float isn't stuck, it may have to be adjusted. Probly have to drain/drop tank to do this. Not a pretty picture, but remember that this Cobra stuff is a thing of "passion". My tank has a plate in the top that can be removed. The sending unit is attached to it. You may have the same set up, but nevertheless, you'll have to drop the tank.
Good Luck . . . NO SMOKING!!!
'bacher
