Old 05-24-2004, 10:55 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
The fittings don't have anything to do with the travel of the TO. The part of the TO that has lines going to it just sits there, it doesn't move. Fittings will not restrict it's non-movement
If your clutch master is not properly sized (probubly ain't) then you NEED a pedal stop.
