Old 05-28-2004, 12:39 PM
FeWedge FeWedge is offline
Cobra Make, Engine: Kirkham 496 Aluminum Tunnel Port 687 hp 653 trq
I would say there is no way your combo will make 600. With your cam and depending on the ported Edlebrock heads , I would think you need be to in the 13 to 1 range. Why did you go with such low compression on a standard stroke 427? With alum. heads you can run a full point higher than iron.
Rob
