Thread: will not time
Old 06-04-2004, 06:32 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
If it is an older engine, and the timing is very eractic, you could have a timing chain problem.
With the dist. cap removed, use a breaker bar and turn the engine back and forth watching the rotor. If there is a lot of play in the crank, you could have a bad chain. On a scope this will have the "Snake" effect in the timing. Hard to time and will run like crap.
Just a thought.
