I would start with the timing chain, also check these things:
1. Make sure you're distributor is not 180 degrees off
2. rotor on top of your distributor
Make sure the rotor is seated into your dist & the screws are
are tightened all the way.
3. Harmonic balancer...
4. Did you degree your cam?
"Let's roll"
"Be part of Something Good
