Old 06-07-2004, 05:15 AM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
OK then, It's a two piece unit. The part with the "L" bracket is left alone. Cut off the two ends with the bolts 1/2" from the end. Then cut the additional ammount you want off,and then cut that same total ammount off the short end. Lastly, weld the bolt ends back on. I'm sure you have a chrome bar, but the welded part will be below the body and out of sight. You'll also have to redrill the back bar. If you need any more help, email me with your phone # and I'll call you if you like.
" It ain't no big deal"
