dimensions
haakerp,
For instance the body cuts for a AC windscreen are usually are 1296mm apart to the inside faces of the side attachment bars, and are 62mm x 12mm openings. Measured across the surface of the aluminum cowl the are 1320mm apart to the inside faces.
This is for an AC, but you should use a windscreen and measure it to get YOUR REQUIRED DIMENSION, in that way since the Originals vary a few mm's from the current market. A NOTE; between the three suppliers world wide they vary between each other a few mm's.
Then the angle, that would be a function of the compounding cowl radii and the location of the side bar supports on the cowl support, who knows, your fabricator would.
Dangerous game without the parts in hand.
grumpy
