Old 06-08-2004, 09:43 AM
DaveR DaveR is offline
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Thanks for the reponse Terry. The McLeod instructions do mention that the tranny needs to be drilled. Which clutch are you using? Did you drill out the threaded holes in the McLeod adapter and screw the bolts into the tapped hole in the steel scattershield, or did you use the flat head bolts to mount the adapter, with the tranny bolts into the threads in the aluminum adapter? How deep did you set your ball stud?
