Old 06-08-2004, 10:49 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Thumbs up Sounds like you have plenty of carb
My 514 rebuild with Edelbrock Torker 2 intake just dyno-ed at 576 HP and 622 ft-lbs torque, with a Demon 850 carb. The powerband and HP were lowered a bit due to the intake, but VERY good low end/wide band torque was the result.. (a good deal IMO) I had the Demon 850 leaned out as much as possible prior to this, because it seemed to be too much carb. A smaller carb will give you better low end use-ability. The guys at the rebuild shop tuned/cleaned the carb for me for my start-up
I will be going to a 1000 cfm air door and Holley Pro-jection EFI soon, but the computer controls will decide how much air/fuel, so the specific cfm is not necessarily directly related to full useage of same.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
