Old 06-09-2004, 06:31 AM
aumoore's Avatar
aumoore aumoore is offline
Cobra Make, Engine: Hunter 427, 5.0 (302)
Default Re: Trailer Strap Points
Originally posted by OhBuoy
Where is the best place to put the tow straps at the front of the B&B? When I took my car for inspection, I looped axle straps over the lower control arms, however, this did not seem like the strongest part to be attaching to. When it went to the painter, I strapped to the frame member behind the radiator, and this worked well, however, this is not accessible when the radiator is on.
Thanks,
Tom
Tom
I should hope the lower control arms are strong enough to hold the car steady on a trailer. Remember they hold the car up. You could bolt on a set of hooks to the frame or have some loops welded onto the frame. Just remember you are trying to prevent the car from moving not trying to pick it up so you do not need an attachment point that is stong enough to stop a sherman tank.
I have used the thru the rim method on my Crager ss rims but my race rims do not have a big enougn hole to pass the straps thru. I have my straps hooking to my front control arms and the rear axle.
