If you go to the 13" caliper setups, you are going to have to use the 17" rims.
Basically, the axel is probably the 2" bolt variety, ford nine inch. You will have to tell whoever you are getting the caliper anchors from, that is the bolt size. ( you could actually measure the distance between the bolts and know for sure ). Remember, there are three major NINE inch ford rear axels, it would be a good idea to know which one you have.
If you have an 8.8, I do not think I can shed any light.
LoneStar gave you a twitch?
