Old 06-11-2004, 02:24 PM
EarlsflyinCobra's Avatar
EarlsflyinCobra EarlsflyinCobra is offline
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Help?????????????????
Started puttong my engine together today and ran into 3 problems;
1. Put the girdle and oil pump on and now my oil pan will not fit on the engine. I went to a standard, single hump oil pan and the standard 302 oil pick up, not the long one....where did I go wrong???????????????
2. I put the camshaft in and it slides back and forth about 1/4 of an inch after I put the thrust plate on. Probably not a problem because the timing gear bolt will hold it from going back and forth, right?????
3. After I put the cam shaft bolt in the timing gear end the back of the timing gear hits on the bolt and prevents the engine from turning????????????
HELP??????????????????????????????????? Please....
Safe Flyin, errrrr Drivin, Earl
