blykins,
I had the same problem. Passenger is centered perfectly and driver side was not centered. From the pics, it seems that your headers are not ceramic coated so you can reposition the pipes without ruining the paint/ceramic coating. I had a template built for the pipes that kept all four pipes together. While adjusting, it maintained the distance between each pipe. It is not the pefect solution because the driver's side is still off center a little but it is not bad.
Shell Valley Cobra
Southern Auto 351C / 4 sp Toploader
Jodeco Auto Paint (Bruce B)
