CSX 4027 Steve your blood pressure is going up
Relax. In a month you and the rest of us will know the answer to the holy grail. I have asked a couple of these guys what cam is in these motors and nobody seams to know or is not saying, Small roller is what is writen. I am looking at rollers myself and crane has the smallest of the major companys. All the others are custom cams at 375.00 per. One note, you can do alot more with a roller cam with openings being faster, valve staying open longer and closing faster. I am sure that ther is some HP and Tork to be found there. Don't forget, they are looking for 75 hp, they don't care about tork. Advancing a cam can give a 20-40 hp advantage on the same motor. I retarded my cam for tork, lost 22 hp and picked up 37 lb of tork with no other changes. I due not know how long Kieth worked with Kuntz but if it is anything like Warren Johnson and Greg Anderson, Look at those two. Greg been kicking butt for 2 years when the car or driver doesn't have a brain fart. This could be the same thing, someone has to pick the torch and run with it
