Old 06-14-2004, 12:15 PM
decooney's Avatar
decooney decooney is offline
On my motor, we found that with all the required oil passage and drainback blueprinting completed, we still had to slightly restrict oil to the heads when using a high volume/pressure oil pump that I chose. Otherwise, oil still pooled too much. Ran it on a motor stand for a bit til we got the correct amout of restriction. I would venture to say it might be a little different with each motor dending on who does the work and how its set up. Good Luck.
Duane
