When are you seeing smoke? Is it only when you first start it up? Or is it when you shift? Or is it a continuos puff of smoke when you are cruising? Also, what color is the smoke? Black, blueish/white or white?
Depending on the symptoms, could be very different things.
Replica is not a dirty word.
