Old 06-15-2004, 03:06 PM
BB427 BB427 is offline
Cobra Make, Engine: 427SC Unique
Default 427 Cobra For Sale
Unique 427 SC
Titled 1965 Cobra
Candy Apple Red
Ford Performance White Stripes
Compomotive 15" Wheels
Custom Made Spinners
Powder Coated Chassis and Components
Aluminum Engine Compartment Backed With Thermo-Tec
Polished Aluminum Radiator, Oil Cooler, and Fans
Billett Aluminum Fan Mount
Tri-Bar Headlights
Chrome Overiders
402 CI FE
Flat top Pistons
C7AE-B Rods
Comp Cams .605 Lift Solid Cam,Lifters,Springs,Retainers,Locks
Edelbrock Stage 3 Ported Heads
Canton Road Race Pan,Windage screen, Scraper
Blue Thunder Weber Intake
48 IDA Weber Carbs flowed by Pierce Manifolds with Custom Velocity stacks
Intake and Webers are Silver Pearl Coat Metallic
All Polished Stainless Screws and Bolts
All lines Polished Aluminum and Stainless
MSD Pro Billet Dist, 6 AL, High Vib Coil, MSD 8mm Wires
Aluminum Roller Rockers,Billet Shafts,Billet Stands
Billet oil pump drive
Edelbrock Aluminum Water Pump
Griffin Aluminum Radiator
Billet Pulleys
All Aeroquip plumbing front to rear
McLoed Aluminum Flywheel
Hays Long style Pressure Plate and Disc
McLoed Hydraulic throwout bearing
Stainless Braided Brake and Clutch lines
Wilwood Brakes, Master Cylinders,Pedal Assy.
All Front Brake Components are Safety Wired
All Rear End Center Section Bolts are Safety Wired
Close Ratio Toploader (fresh)
Jaguar IRS Rear Suspension
1/4" T-6 Aluinum Bottom Brace
Jaguar Emergency Brakes
4 Carrera Chrome Coil overs
3.54 Gear Set
Auburn Posi Unit
Custom A-Arm front suspension
Chrome Carrera Front Coil Overs
180 MPH Reverse speedo
AC Pedals
Custom Toploader Heaven Bent Handle Shifter and Linkage
Chrome Roll Bar
Chrome Emergency Brake Handle
Windwings and Sunvisors
Ceramic Coated Sidepipes and Headers
Leather Seats, Driver side adjustable seat track
New Simpson Belts
Custom embroidered "snake" Floormats
If it ain't painted its POLISHED
Car has 317 miles on it.
*The car won Best 427 at the Unique Homecoming this year
*Best paint and motor at the Nut Club Muscle Car Showdown in April
*Best Ford in show at RiverCity in Feb.
*The car was photographed for 3 hours by Kit Car Mag. in Alabama on 5-16-04 for a future issue.
I will update the photos in My Gallery tonight. There are no finished photos in the gallery right now. The car is as close to perfect as I could do. I sent the body 3 states away to find just the right painter that would do the work the way I wanted it done. I sent the side emblems back three times to get a set that was perfect. This is a car you can set next to any Cobra at any event anywhere. I PROMISE.
The car rides and drives flawless and the Webers are nothing short of awesome. It idles at 500 rpm and still pulls strong past 6,500 rpm.
Thanks for your time,
Brent
