Old 06-16-2004, 10:36 AM
Mike Simard Mike Simard is offline
Cobra Make, Engine: Porsche 928 S4
The aluminum blocks are better than a stock block aside from the weight. They have 4 bolt mains, blind tapped head bolt holes, taller lifter bores for roller lifters and larger bore capability. If you can afford it, it's a very good thing to have.
Yes, you will feel the 90 lbs missing. The steering will be lighter and your car will turn in better.
