Old 06-17-2004, 12:29 PM
tblackgt350 tblackgt350 is offline
Yeah-
On a GT350 or mustang mounting the carbs with the passenger fuel ine inside and the driver side fuel line outside is by far the best way to go. A small block cobra is different; it is easy to mount a bellcrank near the firewall and a shaft that runs straight down the middle between the carbs with levers going to the left and right which open the carbs up by twisting the shaft.
Tim
A good friend will help you move.
A real good friend will help you move a body.
