Holley carb jets in the
oil passage in the head that feed the rockers. Depending on what cam you have solid or hyd and type of heads ( oem or edel ) will determine jet size to be used. I've heard of others using a piece of pushrod tube also but have not used that method myself. I'm using .070 restrictors with a HV pump and solid lifters myself. G.
