Thread: weber carbs
Old 06-19-2004, 05:35 AM
Jinx Jinx is offline
I have a 120 Idle jet holder, will try a 130 see what happens, also will try 45 jet as soon as they get here....I was told that the Ilde jet took you to 2500 to 2800rpm then the mains kicked in ?? if this is true I should be able to get my plugs looking good in that range then go to higher rpms to check the mains.....do the mains .air cor, emu tubs work at all under 2500rpm ..thanxs chuck///hey Atlanta if you had a brain I might ba insulted but then again dont argue with a 2 year old 10/4
