Old 06-19-2004, 05:21 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
If it is a Holley it could be jets, accelerator pump springs, float levels, sticking choke if so equipped, vacuum leak, weak fuel pump delivery pressure, clogged/hampered air cleaner element(the oval Cobra style aren't all that good for air delivery) and a myriad of other ailments.
Can you tell I'm not enamored with the vaunted Holley I spent close to $150 on rebuild kits, jets, etc. on my Holley--I put the Edlebrock on changed one set of metering rods and my car has never run better.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
