  #21 (permalink)
Old 06-23-2004, 03:44 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Terry:
The 600 ratios are pretty close to the wide ratio top loader numbers and, if you run out the numbers, should give you streetable results with either a 3.31 or a 3.07.
DonC
