Rick,
I kinda figured out the whole Ford cam pin thing about 25 years ago
Also I only use Loctite 271 on a cam bolt and torque it to the proper specs
The Comp Cams Hex-adjust timing set is a new thing that Comp Cams has released. The kit uses a 2nd, smaller dowel pin to allow cam timing adjustments to be made without having to remove the timing set.
It is too much effort to explain exactly what it looks like but it is different than a standard timing set.
You have to see one to understand what I'm talking about.
Maybe I'll take photos of the one I have.
I'll have to dig it up off the floor cause I'm using it to level out the leg of my work bench
--Mike
