Old 06-26-2004, 01:10 PM
CC5S CC5S is offline
Bill:
Here's a break down of the gear ratio for the Tremec Ford TKO 600's:
TKO-600 (part #5008) 1st = 2.87 2nd = 1.89 3rd = 1.28 4th = 1.00 5th = .64
TKO-600 road-race (part#4617) 1st = 2.87, 2nd = 1.89, 3rd = 1.28, 4th = 1.00, 5th = .82
Both will handle 600 ft/lb torque
If you are looking to race (keep RPM's up) in 5th then you should consider part # 4617. If you want to cruise in 5th then you should consider # 5008.
Also make sure you check into what rear gears your are going to run.
Scott Lindquist
- Classic Chevy 5-Speed
Phone: (559) 897-9500
http://www.ClassicChevy5Speed.com
