Old 06-30-2004, 06:46 AM
MidOHasp MidOHasp is offline
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Lowell,
Sorry I never met up w/ you at the Fling... i was looking forward to it!
Sounds like your problem WAS identical to mine. So the adjustment theory is hopefully correct. I wish I knew what could have possibly caused this. I know I have a leaky clutch line that I'm going to replace, but I'd assumed that would cause the opposite problem. I wouldn't be able to disengage the damned thing. In any event, glad you got yours fixed up. The pushrod I have between the slave cylinder and the fork is threaded, so I will adjust it back a wee-bit.
Thanks all...
JP
J.P.
Ohio Cobra Club
Token Gashole
