  #41 (permalink)
Old 06-30-2004, 08:57 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
ChuckG
I know the feeling, mine sat for 2 months after I got it. Took that long to get it insured and registered. Talk about anticipation.
I don't know whats worse, finding out the lights don't work immediately or driving it for 2-3 months before someone told me about it. Think of all the times I could have been rearended. Just lucky I guess.
I was able to fix the problem very easily by going to a CARQUEST auto store and buying part #SLS-66 (switch stoplight). Its a mechanical switch that is cylindrical in shape with a push button on the one end and threads for adjustment on the other end, $8.00. I was able to bend a bracket for it out of stuff I had laying around. (L brackets) I attached it to the square plate which holds the throttle cable in place, already had the hole drilled through it. Then I disconnected the two wires from the brake pressure switch and pulled them back through the fire wall over to the new switch and connected it. PRESTO I now have brake lights that come on with the slightest tap of the pedal.
I'll be honest, it took me about 2 - 2 1/2 hours to do, only because it is a very tight, awkward place to work and I tried different brackets which I bent either too much or to little. Its not complicated at all, just challenging, and I'm not a big guy. Next time I would put the car up on jack stands to get it off the ground, that might make it a little more comfortable to work on.
Hope this helps and good luck with the car.
Welcome to the club !!!
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
