Old 06-30-2004, 08:59 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Guess I'll throw my stats.
428 FE (.60 over) 435 ?
Stock crank & rods.
Keith Black slugs.
Custom grind Comp Cam- (solid flat tappet) Lift 600/600- Tappet lift 290/298- Duration at .050 252/260- Lobe sep. 110
Comp Cams may produce this grind ? We'll see. I wanted something different for our light weight Cobras.
It likes to idle at 1,100 rpm's. Sounds real loppy then & at 2,000 cruising speed. Very happy with it.
Was dynoed at the flywheel. 501 hp
Chassis dyno results.
Regards,
Kevin
