Doug,
If you have your cam card and a degree wheel, you can check the cam timing without tearing into the engine. But first, if I were you I would remove #1 spark plug and establish TDC compression stroke on that cyl. .......does the harmonic balencer's "0" mark coincide with TDC on #1?? If yes, then check for other problems.
Steve
All my ex's live in Texas
