Old 07-02-2004, 04:36 AM
MidOHasp MidOHasp is offline
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Originally posted by GeorgiaSnake
Could I have glazed the clutch disc when this first happened?
Randy
New question, thanks for bringing up that possibility...
If that's the case, can you score the clutch disc surface with some sand paper to remove the glaze? Had that happen to some brake discs once after a day at the track. Though I toasted the brakes, but I just bled the fluid and hit the pads with 100 grit for a few seconds. Like new...
Clutch seems like a different animal. Maybe not?
J.P.
Ohio Cobra Club
Token Gashole
