Old 07-02-2004, 10:46 AM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Pat Buckley Rick Lake Pat Rick I am not sure I want to put the damn thing in from what you guys say it looks like about 1200-1300 bucks to put in a proper and good external oil pump and lines with oil pan modifications even if I use a wet sump and it sounds like you agree regarding the price of going the full dry sump route at least within a few hundred bucks I do plan on open track and autocrossing with this car but long hard drives are what I do now and while I don't mind checking the freeking distributor gear every few thousand I would prefer not hearing one of those little basturds "snap" again and think I have blown the whole damn motor but if I do it it will be a wet sump hookup at this point and I appreciate the discussion you two are having because it has detailed what will be involved here are the periods I didn't use thank you both.......................................
kanuck
Many thanks. I'll check out Moroso.
Jamo
