Pat Buckley HEY Pat. YOU got screwed if you payed $600-800 for an
oil tank. First an Aviaid 12 qt 9" round is 346.00$, same in Moroso is $510.00, ARE is $465.00. I didn't get a Stef price but around $450.00. If I wanted to go Cheap, Speedway is $184.00 All the same size tanks, one you add $65.00 for more inlets. Only differents is how many baffles are inside. A good used one is in the $250-300 range. I don't know everything about cars, but I ask alot of questions and don't sound like you. The prices I gave where from a current Avivad Price list. You had an ERA car, saw it in your pictures. I guess the step up makes you better than ever. I am running a roller in my next motor, FI system with a Danny Bee timing set, I don't want to have the distributor gear being torn up either. How ever, how many people know how to CORRECTLY set up Camshaft end play and check it, How many have the WRONG gear Material on there Distributor??You being a multi talent, mutli purpose racer would know this stuff. Maybe Jamo doesn't. As far as fitting the tank in the R/S fender with cut the footbox up I will let you know when it is done. We agree on multi options for the oiling system, I was just doing the same thing as you but if you are in for a foot, you might as well do the yard and know that everything is better in the long run. Hav a good afternoon Pat. Rick Lake
