if money is no option canfield heads are as good as it gets as far as heads go. im looking to go with a set of AFR there right up there with the canfieds but there 1/3 of the price. sounds like the lower end will be good, billet aluminum flywheel would be a good choice depending on your output but will give some rpm because of the light weight. tranny wise i would say either TKO2, or tremic i would call tremic and tellem what u wana do with your car and theyll tell you what to get for your application. The best resource for any SB ford owner is muscle mustanges and fast fords magizine.
