i have a BIG favor to ask someone. can someone give me a list of specs including wheelbase, length, height(top of windscreen), width, dry/loaded weight(i know it depends on the engine), ground clearance, weight distribution, and drag coefficient. If you can answer some of these it would be a huge help. the reason i ask is that when you compare the superformance and factory five specs, the superformance is bigger in everything except dry weight, so i need to know whats closer to the original. one must not look right.
