Genuine FT 391's are highly prized. Because its a truck block, the bore will support overboring to 428 size. Maybe even 427 size depending on a good sonic test. Look for a larger than normal distributer hole in the block. A FT dizzy has a larger diameter shaft but a reducer will allow a standard FE dizzy to be used.
John
