Old 07-06-2004, 06:22 AM
chuckbrandt's Avatar
chuckbrandt chuckbrandt is offline
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default 390 is waiting patiently.
Wickedfast -
The 390 is the next project after the paint is done. You've seen my garage! I can't have the "paint booth configuration" and the "engine building configuration" active at the same time!
I actually can't wait to dig into the 390 build. First step is to final clean the block that Gessford did for me. Then check the clearances on the crank and rods. Then assuming all is well with the clearances take everything over to K&M for a balance job. Then start putting it together, everything else should be ready to go.
Good luck with the house painting
Chuck
Build website at www.chuckbrandt.com
