If your signal lights work with the ignition off, simply use a SPST switch to connect the left and right signals. To get all 4 to work at once, use the turn signal switch to turn either side on and flip the connecting switch on.
If you don't have power at the signal switch all the time, use the other half of a DPST switch to power the flasher from a power source.
