Old 07-06-2004, 03:55 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Keith:
You can run out the theoretical number using any of several gearing/speed calculators. Here's one that I've found to be pretty easy to use, just plug in the numbers for gear ratios, rear end ratio and tire size.
This should at least put you in the ball park.
http://www.368s.com/tools_rpm.phtml
DonC
