Got the rear end tightened up....
the lower A arm frame attachment was loose. Taking it apart was easy getting it back together a different story. You can't jet the joint back together without pulling the whole mess apart.... front control arm, coil over, sway bar etc. Its all together now. The problem is the nuts with the o rings don't lock and come loose.
I'll bet the MG/Ford was a scream...how's the electrical?
Roland
