Old 07-09-2004, 10:11 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
I used the jacks in the wheel dollies to support the frame as I was prepping it. The problem I had was that 4 points do not make a plane, so one was always loose. Once the engine and rear end were in, it got a lot more stable.
I'd say if you were handy with a welder, you could weld a raised support on top of the dollies to lift the car higher. Match the height with the max lift you get off of the jack and voila.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
